It is currently Sun Nov 22, 2026 1:49 pm
PostPosted: Tue Aug 14, 2007 11:19 pm
Should I install new tube o-rings:
1. Dry
2. smeared with a little oil
3. smeared with a little grease
4. smeared with a little hylomar
to get the best seal??????????
PostPosted: Wed Aug 15, 2007 5:42 am
Dry. They'll get plenty oily on their own.
PostPosted: Wed Aug 15, 2007 7:03 am
If they are new, dry is fine.
Once they are a bit old, I just put a little permatex around the edges and I never have leaks...
PostPosted: Wed Aug 15, 2007 11:38 am
Should these tube o-rings be replaced at every plug change or less often? Are they used on 1979 /6?
PostPosted: Wed Aug 15, 2007 12:33 pm
Depending on your maintenance philosophy, the answer is either "about every 2 to 4 spark plug changes, depending on how fastidious you are" or "Every three decades, whether they need replacing or not".
They're used on 1960-1974 slant-6 cylinder heads. 1975 and later heads don't use plug tubes, therefore no plug tube seals.
PostPosted: Wed Aug 15, 2007 12:55 pm
Thanks Dan!!! This site is excellent and you guys are GREAT!!!!!!!
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 8 guests
