| Best spark plug tube sealing..... https://slantsix.org/forum/viewtopic.php?t=24475 |
| Author: | emsvitil [ Tue Aug 14, 2007 11:19 pm ] |
| Post subject: | Best spark plug tube sealing..... |
Should I install new tube o-rings: 1. Dry 2. smeared with a little oil 3. smeared with a little grease 4. smeared with a little hylomar to get the best seal?????????? |
| Author: | SlantSixDan [ Wed Aug 15, 2007 5:42 am ] |
Dry. They'll get plenty oily on their own. |
| Author: | Dart270 [ Wed Aug 15, 2007 7:03 am ] |
If they are new, dry is fine. Once they are a bit old, I just put a little permatex around the edges and I never have leaks... Lou |
| Author: | thomasj6604 [ Wed Aug 15, 2007 11:38 am ] |
Should these tube o-rings be replaced at every plug change or less often? Are they used on 1979 /6? |
| Author: | SlantSixDan [ Wed Aug 15, 2007 12:33 pm ] |
Depending on your maintenance philosophy, the answer is either "about every 2 to 4 spark plug changes, depending on how fastidious you are" or "Every three decades, whether they need replacing or not". They're used on 1960-1974 slant-6 cylinder heads. 1975 and later heads don't use plug tubes, therefore no plug tube seals. |
| Author: | thomasj6604 [ Wed Aug 15, 2007 12:55 pm ] |
Thanks Dan!!! This site is excellent and you guys are GREAT!!!!!!! |
