Slant Six Forum https://slantsix.org/forum/ |
Hood to carb clearance on '62 v200 https://slantsix.org/forum/viewtopic.php?t=24494 |
Author: | greasy 225 [ Thu Aug 16, 2007 4:16 pm ] |
Post subject: | Hood to carb clearance on '62 v200 |
I was wondering what the hood cleaance is on the ealy A body with a 4 barrel manifold(mines an Offy)? I havent on an carb yet but id like to use the stock slant air cleaner with a different base. is there enough cleanance or will I need a drop base cleaner? Thanks. -Jesse |
Author: | SlantSixDan [ Thu Aug 16, 2007 5:20 pm ] |
Post subject: | |
Air cleaner to hood clearance is always really tight on the '60-'62 A-bodies with 225 engine. You'll definitely need a drop-base unit. |
Author: | greasy 225 [ Fri Aug 17, 2007 10:55 pm ] |
Post subject: | |
I figured as much, just hopein someone had done it, or maybe i'll do a '57 T-bird scoop on the hood! Thanks Dan. -Jesse |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
