It is currently Mon Nov 23, 2026 12:33 am
 Post subject: High Starter ?
PostPosted: Sun Aug 19, 2007 6:29 am
Hey I was just looking on ebay and there are a set of headers that require a high starter location? I have a 73 225 slant six from a dart installed in my 1956 Dodge pick-up does this have the high starter or the low starter on this motor and how can you tell ? Thanks http://cgi.ebay.com/ebaymotors/Mopar-Ca ... enameZWDVW
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Sun Aug 19, 2007 7:40 am
Hi DOdge,
It is right easy to tell. High mean the starter bolts to the bell up where the cylinders are on the block and you can remove it easily from up top. Low means it is almost out of sight and you may find it easiest to lay under the vehicle to remove the starter. Dunno about cars but I see you have a truck..me too...so if you have a low mount you will be in the so called "universal" cast iron bell with the big clutch....assuming you are basically stock. If you have another tranny besides the 3 speed column shift you may have another bell....still, low...you get under, high, right up top.
rock
'64d100
PostPosted: Sun Aug 19, 2007 7:43 am
The low starter was also used on the adapter plate that mated a Slant to a small block 727 in trucks, taxi's, and police cars. :shock:
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 10 guests
