| rear end gears for my 71 Demon https://slantsix.org/forum/viewtopic.php?t=24502 |
| Author: | 71_demon [ Fri Aug 17, 2007 8:47 am ] |
| Post subject: | rear end gears for my 71 Demon |
Hi All, I searched the archives and couldn't find the answer so here goes. I have a 71 demon 225 slant six. I have parts to convert it over to the super six. I would also like it to grab a little more out of the hole and I read some where that rear end gears can help. Finally to the questions. Is there a better gear setup for the demon than just the stock? And is it something I can find in the junk yard? Finally, is there a setup that I can just change the gears out or do I need to swap the drive shaft etc..? I know its not asking for to much to have a pull and swap Thanks Jeff If you always do what you've always done, then you always get what you always got. |
| Author: | Romeo Furio [ Fri Aug 17, 2007 4:58 pm ] |
| Post subject: | demon |
Utah should still have some old 60's Darts and Valiants in the wrecking yard. My 63 Valiant has 3.23's my 67dart had 2.93's. Your car may have 2.93 or 2.76. Randys ring and pinion may have as deep as 3.91's. I am assuming your car has a 7.25" rear axle. If you are lucky you may even find a sure grip. |
| Author: | Ron Parker [ Fri Aug 17, 2007 6:22 pm ] |
Look for a 60ths dodge van Slant six. they were common so was the pick up trucks. Slant six. Most trucks and vans came with either 3.55 gears or 3.91 gears With the Slant engine. Look on the door post and it will show you the gear ratio. Doint matter if it is a 741 case it will bolt right up to a 742 or a 489 case. Probaly get the whole rear end for fifty dollars. |
| Author: | 71_demon [ Fri Aug 17, 2007 6:55 pm ] |
| Post subject: | Awesome stuff guys |
great stuff guys, So which set should I look for to have the demon grab a little more?? Thanks for the info. Jeff |
| Author: | Joshie225 [ Fri Aug 17, 2007 8:03 pm ] |
Your car if it's an automatic probably has 2.76 gears so anything numerically higher will improve acceleration. 3.23 is about as high as I would go for a stock slant. Having more RPM available or a taller tire will support/require numerically higher gears. It's probably going to be tough to find 7 1/4 rear end gears numerically higher than 3.23 used. Look for Dakota 4 cylinder pickups and check the decal under the hood to see if you can get something decent. Otherwise... http://www.drivetrain.com/chrysler7.5.html |
| Author: | 71_demon [ Sat Aug 18, 2007 3:06 am ] |
| Post subject: | What about the speedometer |
Got some great info and can't wait to do one of my favorite hikes through a junk yard in Grantsville Utah. I'm curious though if I switch to a different gear ratio how will it affect my speedo? |
| Author: | Rug_Trucker [ Sat Aug 18, 2007 7:00 am ] |
Mine cruises comfortably all day at 80 with 3:23's. |
| Author: | Jeffc [ Sat Aug 18, 2007 12:55 pm ] |
| Post subject: | Re: What about the speedometer |
Quote: Got some great info and can't wait to do one of my favorite hikes through a junk yard in Grantsville Utah.
Yes, a differant ratio will change how the speedo reads.I'm curious though if I switch to a different gear ratio how will it affect my speedo? If you find a doner 904 with the gears you want in the rear end just grab the speedo gear out of the trans to match the rear end. Randys is a good place to start for a new ring and pinon (there are other sellers, but mamopar is very high price), your going to want to check your spider gears for slop--- spiders are the real weak link in a 7.25 axle and there not that much money to replace if the center chunk is already out of the axle...... Dekotas in the 80s have the 7.25 alxe and are pretty common. D100/150 trucks will have 8.75 or 8.25 depending on year and are not compatable with the 7.25 axle. 3.23 is a pretty good all around gear set for a stock application 904, but about as low as I would go, unless you what stop light to stop light action and don't care about freeway driving, then 3.55 would be better. You may have the 2.94 or 2.76 (aprox numbers) now. There are axle differances with the gear sets, not all can be swapped gear set for gear set. You really need to find out what your gear ratio is in your 71 before setting out to find a set to swap in unless your going after the hole axle. This would come up if you have the 2.76 gears now, then a axle case swap would be needed. |
| Author: | 65 dartman [ Sat Aug 18, 2007 3:47 pm ] |
Quote: Look for a 60ths dodge van Slant six. they were common so was the pick up trucks. Slant six. Most trucks and vans came with either 3.55 gears or 3.91 gears With the Slant engine. Look on the door post and it will show you the gear ratio. Doint matter if it is a 741 case it will bolt right up to a 742 or a 489 case. Probaly get the whole rear end for fifty dollars.
| Author: | 65 dartman [ Sat Aug 18, 2007 3:52 pm ] |
Quote: Quote: Look for a 60ths dodge van Slant six. they were common so was the pick up trucks. Slant six. Most trucks and vans came with either 3.55 gears or 3.91 gears With the Slant engine. Look on the door post and it will show you the gear ratio. Doint matter if it is a 741 case it will bolt right up to a 742 or a 489 case. Probaly get the whole rear end for fifty dollars. |
| Author: | Jeffc [ Mon Aug 20, 2007 12:29 am ] |
Quote: Quote: Quote: Look for a 60ths dodge van Slant six. they were common so was the pick up trucks. Slant six. Most trucks and vans came with either 3.55 gears or 3.91 gears With the Slant engine. Look on the door post and it will show you the gear ratio. Doint matter if it is a 741 case it will bolt right up to a 742 or a 489 case. Probaly get the whole rear end for fifty dollars. and none of the 8.75 stuff is compatable with a 7.25 |
