It is currently Sun May 24, 2026 1:09 pm
PostPosted: Thu Aug 16, 2007 4:16 pm
I was wondering what the hood cleaance is on the ealy A body with a 4 barrel manifold(mines an Offy)? I havent on an carb yet but id like to use the stock slant air cleaner with a different base. is there enough cleanance or will I need a drop base cleaner? Thanks.
-Jesse
PostPosted: Thu Aug 16, 2007 5:20 pm
Air cleaner to hood clearance is always really tight on the '60-'62 A-bodies with 225 engine. You'll definitely need a drop-base unit.
PostPosted: Fri Aug 17, 2007 10:55 pm
I figured as much, just hopein someone had done it, or maybe i'll do a '57 T-bird scoop on the hood! Thanks Dan.
-Jesse
