Slant Six Forum https://slantsix.org/forum/ |
alternator compatibility question https://slantsix.org/forum/viewtopic.php?t=24513 |
Author: | daveca5150 [ Fri Aug 17, 2007 9:25 pm ] |
Post subject: | alternator compatibility question |
Is there any problem with putting a double pulley 73' alternator in a '63 valiant that only needs a single pulley? I need an alternator and there's one for sale locally. Thanks |
Author: | slantzilla [ Fri Aug 17, 2007 10:18 pm ] |
Post subject: | |
The '73 will have dual field wires. The '63 is a single field. You can make it work by grounding one field terminal to the case with a short piece of wire and a couple terminal ends. You will need to run the belt on the inner groove. |
Page 1 of 1 | All times are UTC-08:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
