Water pump - play in pulley normal?
https://slantsix.org/forum/viewtopic.php?t=24514
Author:  Pierre [ Fri Aug 17, 2007 11:40 pm ]
Post subject:  Water pump - play in pulley normal?
Noticed a bit of play in water pump pulley when trying to track down a noise. This was a GMB made in japan unit, maybe 10-12k miles on it. I replaced it with a napa unit (said made in canada on it, casting marks aren't the same so it does appear to be a different unit not just a same thing different box rebadge job). I notice the same play.
Its not a radial play or wobble, but more of an in/out movement. Don't need incredible force to feel it either, just pinch the fan between two fingers, ease it forward/backward and you can feel it and see the pulley move as well. Is this normal, or did I just get bad luck with the new pump?
Author:  SlantSixDan [ Sat Aug 18, 2007 7:22 am ]
H'mm. I think you're having bad luck...I can't remember ever experiencing this axial play you're talking about, but I surely don't like the sound of it! :shock: How much play are we talking about here?
Author:  Pierre [ Sat Aug 18, 2007 7:41 am ]
Maybe 1/32 guestimating? I didn't put a gauge on it. You can also feel it, like its not a smooth in and out it feels like something is hitting a step or falling into a notch, if that makes sense. The new one had less play then the old - I replaced because I was afraid of loosing a radiator too. It spins freely by hand w/o any noise.
Author:  1974duster kev [ Sat Aug 18, 2007 9:36 pm ]
Try tightening the fan bolts to the water pump?
Kevin
Author:  Pierre [ Sat Aug 18, 2007 10:04 pm ]
They get any tighter the threads will strip :lol:
Next time you have the hood open try it - pinch the fan between two fingers and push forward and back, while watching the pulley carefully and feeling for any play.
