It is currently Wed Nov 25, 2026 12:37 am
 Post subject: Comparing Engines
PostPosted: Mon Aug 20, 2007 4:36 pm
What makes a newer engine with the same or about the same liters as the slant put out more stock horsepower and torque?
Go for it, You live this life only once.
PostPosted: Mon Aug 20, 2007 4:45 pm
About 46 years of technological advancement in engineering designs.
Take electronics alone in monitoring your engine, much less physical advancements like roller cam technology, shorter strokes for higher rpm, head designs, manifold designs, exhaust system designs, etc......
PostPosted: Mon Aug 20, 2007 6:18 pm
As noted above, computer controlled fuel and timing management is the main difference.
