| vacuum advance and governor https://slantsix.org/forum/viewtopic.php?t=24557 |
| Author: | JohnnyDees [ Mon Aug 20, 2007 6:53 pm ] |
| Post subject: | vacuum advance and governor |
Are the vacuum advance canister and governor the same in a V8 and /6 distributor? I had them side by side today and they sure look the same. |
| Author: | Sam Powell [ Mon Aug 20, 2007 7:11 pm ] |
The parts will interchange from slant to small block, but the advance is more on the V-8 Sam |
| Author: | KBB_of_TMC [ Tue Aug 21, 2007 11:01 am ] |
Don't forget to notice which way the distributor rotates, V8 A and B/RB blocks are opposite. |
| Author: | Sam Powell [ Tue Aug 21, 2007 8:34 pm ] |
I have switched parts from the small block v-8 to the slant distributors. I was trying to get more vacuum advance on the slant. The vacuum advance pot comes in from the lower left side on both . Sam |
| Author: | Slant6Ram [ Thu Aug 23, 2007 8:36 am ] |
| Post subject: | Some more info |
All electronic Governors are the same on slant sixes and v-8, but you will have to change the reluctor to a 6 point. They are available though parts stores. The reverse model vacuum advance distributors still have a usable governor, but v-8 governors frequently have slots to allow greater than desired advance for a slant six. It is possible to partially fill the slots to the desired size and that information is articled elsewhere on this website. |
