It is currently Mon Nov 23, 2026 10:18 pm
 Post subject: Holley's DVD
PostPosted: Mon Aug 20, 2007 9:37 pm
Site Admin
Has anybody tried Holley's instructional DVD?
Enough info to get deep into a 4150, or should I just buy the book? :lol:
CJ
PostPosted: Tue Aug 21, 2007 1:47 pm
bought the carb new and it came with a dvd in a paper sleeve. I remember watching it twice to absorb the information- it was a good primer if you don't know much about them. I also bought a holley tuning book. All good information, and it was hard to find that much in depth info on the web.
I ended up buying a wideband a/f from innovate. Combined with a vacuum meter I was able to tell which circuits of the carb were being used and whether they were lean or rich. I ended up making compromises in some areas to get others where I wanted them, but it took the guesswork out of the tuning and became a much more linear process.
Anyway, Im not an expert, but I learned a lot and would be happy to share anything I learned!
Good luck
Kevin
madam im adam
PostPosted: Tue Aug 21, 2007 3:42 pm
Site Admin
I'm looking at changing the secondary air bleed to hold the secondary out for a bit more RPM. I'm running O2 and a Vac gauge too. Just trying to get the thing to behave on there. :D
I'll have to start all over with the new engine, and will likely up to the 600 4150 for it.
CJ
Users browsing this forum: Amazon [Bot] and 5 guests
