| large lifter holes on a small spark plug head? https://slantsix.org/forum/viewtopic.php?t=24579 |
| Author: | ValiantOne [ Tue Aug 21, 2007 8:01 pm ] |
| Post subject: | large lifter holes on a small spark plug head? |
Hey all, I am totally new here and I am working on plans for my first /6 build. I recently bought a 66 Valiant with a 170 in it. I've been reading this site for a couple of months as well as various books and web articles. This has led to many questions One of the many things I was wondering is whether or not it is possible to drill out the drain holes in a small spark plug head, big enough to get the lifters out if you want to? Am I asking one of those questions where all the experience guys roll their eye here Cheers, Chris E. |
| Author: | Doctor Dodge [ Tue Aug 21, 2007 10:04 pm ] |
Why not use a 81 and up hydraulic engine "wide valve cover" head? Those have a larger push rod hole which makes "head on" lifter removal possible. Why will you need to remove the lifters after the engine is in the car? DD |
| Author: | ValiantOne [ Thu Aug 23, 2007 7:39 pm ] |
DD, That is exactly why I asked the question:) thank you. If I used the 81 up head I would still get the "better" combustion chamber and the hardened valve seats. I would just have to use the older rockers and hardware right? As for removing the lifters in the car I was thinking about trying a medium wild cam. I figured if I didn't like it, it'd be easier to change in the car. C |
| Author: | slantzilla [ Thu Aug 23, 2007 8:25 pm ] |
Quote: DD,
The 81-up head will require it's own valve cover and also the rear bolt for the rocker shaft.That is exactly why I asked the question:) thank you. If I used the 81 up head I would still get the "better" combustion chamber and the hardened valve seats. I would just have to use the older rockers and hardware right? As for removing the lifters in the car I was thinking about trying a medium wild cam. I figured if I didn't like it, it'd be easier to change in the car. C I have found that on a Slant car it is much easier to install and degree a cam with the motor out. It's just not that hard to pull a Slant motor out. |
| Author: | Joshie225 [ Thu Aug 23, 2007 8:58 pm ] |
I 2nd Slantzilla. I will never again pull an oil pan or timing cover off a slant with the engine in place. |
| Author: | SlantSixDan [ Thu Aug 23, 2007 9:05 pm ] |
Me three. |
