8 3/4 third member removal
https://slantsix.org/forum/viewtopic.php?t=24598
Page 1 of 1
Author:  wicked/six [ Thu Aug 23, 2007 12:10 pm ]
Post subject:  8 3/4 third member removal
Just making sure i have all the tools ready to switch the third member at the track. Will i have to totally disassemble the brakes to get the axel to slide out far enuf or can i just remove the upper springs and the bar?
Thanks for any help!
TF
Author:  Doc [ Thu Aug 23, 2007 1:16 pm ]
No, you will not have to dis-assemble the brakes to swap center sections on an 8 3/4.
You will need an extra gasket and a few razor blades to scrape the old gasket off.
I will bring my special oil pump "can" to the Redding... getting the gear oil back in is the hardest part of the job.
Author:  wicked/six [ Thu Aug 23, 2007 2:18 pm ]
Thanks Doc it sound like i am all ready to head up see ya there!
Author:  Jeffc [ Thu Aug 23, 2007 3:20 pm ]
Axle tube seals and bearing retainer gaskets--
I almost always replace those too when I'm in a 8.75........
just depends on what the old ones look like.
Author:  Fopar [ Thu Aug 23, 2007 4:47 pm ]
Doc;
you are trying to make it way too easy. I am still using the manual pump on the gallon jug. Oh well, guess I am still too old school or to lazy to find and put together what you described at the last Redding meet.
Looks like a lot of us will be swapping third members, Oh the fun.
