| Ex. manifolds https://slantsix.org/forum/viewtopic.php?t=2460 |
| Author: | EdPedrick [ Tue Jul 24, 2001 7:21 pm ] |
| Post subject: | Ex. manifolds |
Have a friend who needs an exhaust manifold for an early 80's Dodge van (198). I have some off earlier 170 & 225's. Would they interchange? Ed P. EdPed@thegrid.com |
| Author: | r [ Tue Jul 24, 2001 7:33 pm ] |
| Post subject: | Re: Ex. manifolds |
: Have a friend who needs an exhaust manifold for : an : early 80's Dodge van (198). I have some off : earlier : 170 & 225's. Would they interchange? Ed P. yes |
| Author: | Doctor Dodge (Doug Dutra) [ Tue Jul 24, 2001 9:05 pm ] |
: Have a friend who needs an exhaust manifold for : an : early 80's Dodge van (198). I have some off : earlier : 170 & 225's. Would they interchange? Ed P. See if the truck has an O2 sensor, some of the real late exhaust manifolds had a tapped hole on the back wall of the heat riser area. Another problem area is the choke pocket but if you have the choke stove for the replacement manifold, you can get around that issue. As far as "bolting-on", yes, it will bolt onto the head. DD |
