| concrete raceblock? https://slantsix.org/forum/viewtopic.php?t=2461 |
| Author: | jyri eramaa [ Wed Jul 25, 2001 5:38 am ] |
| Post subject: | concrete raceblock? |
i know this is weird, BUT if i want to put block hardener in the block, but still retain somekind of waterpassages in it, what would be the best thing to use? you know i would like to strengten the block in the cylinder area, and have small water circulation inside the block... any ideas? http://homepage.mac.com/jyrie jyri.eramaa@jwt.fi |
| Author: | Doctor Dodge (Doug Dutra) [ Wed Jul 25, 2001 3:29 pm ] |
| Post subject: | Re: Concrete SL6 Raceblock? |
: I know this is weird, BUT if i want to put : block hardener in the block, but still : retain somekind of waterpassages in it, what : would be the best thing to use? you know i : would like to strengten the block in the : cylinder area, and have small water : circulation inside the block...any ideas? There is some info. on this subject in the SL6 Block article. Mostly at the end of the story. <A HREF="http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm">http://www.slantsix.org/articles/dutra-blocks/slant-blocks.htm</A> Just don't fill it all the way to the top and use clay or wax to keep the filler out of the waterpump enty area. I have filled blocks about 1/3 the way and cooling does not seem to suffer at all. DD |
| Author: | jyri eramaa [ Wed Jul 25, 2001 11:59 pm ] |
: There is some info. on this subject in the SL6 : Block article. Mostly at the end of the : story. : <A HREF="http://www.slantsix.org/articles/dutra- ... cks.htm</A> : : Just don't fill it all the way to the top and : use clay or wax to keep the filler out of : the waterpump enty area. I have filled : blocks about 1/3 the way and cooling does : not seem to suffer at all. : DD is the block weaker in the bottom? i would think that there is more pressure in the combustion area, but in the lower part the piston is trying to do more of sideways movement...well thanks! i have to try this.... jyri.eramaa@jwt.fi |
