It is currently Mon May 11, 2026 3:34 pm
PostPosted: Wed Jul 25, 2001 7:42 pm
I finally found a A-833 tranny from a Volare to replace my 3 on-the-tree in a salvage yard about a 100 miles from home. I will pick it up on Saturday. It has the sghifter, linkage and bell housing. My wagon currently has a '75 225 with original tranny. Will the flywheel that I am currently using work with the 4 spd? What clutch and pressure plate is recommended? Will the tranny bolt right up or do I need additional parts (i.e. bearings etc.)? Will the clutch fork from my 3 sp work on the 4spd?
I found a floor pan hump from a mid 70s Duster with a 3 spd on the floor...will the hump work in my '66 Valiant wagon? Any other parts I need? Will the original carpet fit over the 4 spd hump?
Thanks,
Gary
theluketribe@hotmail.com
PostPosted: Thu Jul 26, 2001 1:05 am
: I finally found a A-833 tranny from a Volare to
: replace my 3 on-the-tree in a salvage yard
: about a 100 miles from home. I will pick it
: up on Saturday. It has the sghifter, linkage
: and bell housing. My wagon currently has a
: '75 225 with original tranny. Will the
: flywheel that I am currently using work with
: the 4 spd? What clutch and pressure plate is
: recommended? Will the tranny bolt right up
: or do I need additional parts (i.e. bearings
: etc.)? Will the clutch fork from my 3 sp
: work on the 4spd?
: I found a floor pan hump from a mid 70s Duster
: with a 3 spd on the floor...will the hump
: work in my '66 Valiant wagon? Any other
: parts I need? Will the original carpet fit
: over the 4 spd hump?
: Thanks,
: Gary
get everything and then toss what you don't need. Flywheel to last u joint.
I thin that the mid seventies hump might work, but isn't that part of the floor? You need the add on hump. I used an old oil pan becaue I am broke..... OK cheap.
crapett.?? Whats that? can you put oil in it?
richard-c@e-d-a.com
