| Voltage Regulators? https://slantsix.org/forum/viewtopic.php?t=24652 |
| Author: | bwhitejr [ Mon Aug 27, 2007 10:02 am ] |
| Post subject: | Voltage Regulators? |
I have been using the Mopar DCC-4529794 voltage regulator the last couple of years, but notice that they fail too often for me. Is there a better replacement? Summit has a listing for a Standard Motor Products VR125 which costs twice as much. Is it a better voltage regulator? This is an electronic ignition vehicle. What does everyone else use? bwhitejr |
| Author: | SlantSixDan [ Mon Aug 27, 2007 12:18 pm ] |
My experience with the MP voltage regulators (early and late type) has been poor. Maybe they're buying them from the same company providing the ignition orange boxes! The Standard VR-125 is a good unit, as is the Echlin VR-38. As for cost...Summit are gouging on the Standard part, which can be had for under $31 from www.rockauto.com , and you may also want to check locally, since Standard/Bluestreak and Echlin are widely available without shipping charges. Do make sure your regulator has a good ground...scrape paint off the regulator base and run a ground loop to the alternator housing and battery negative terminal, if necessary. |
| Author: | emsvitil [ Mon Aug 27, 2007 12:56 pm ] |
| Post subject: | Homemade |
I ended up making my own.............. http://www.slantsix.org/forum/viewtopic.php?t=22124 http://groups.msn.com/EdSvitilsSportste ... lator.msnw |
