| Solid engine mounts for early(62) A body? https://slantsix.org/forum/viewtopic.php?t=24657 |
| Author: | greasy 225 [ Mon Aug 27, 2007 8:54 pm ] |
| Post subject: | Solid engine mounts for early(62) A body? |
Awhile back someone mentioned that they made solid mounts for the older A bodies outta some square tube sliced in half? If anyone has any insight into this id sure like to hear or better yet see a few pictures so I can make up a set, thanks. -Jesse |
| Author: | greasy 225 [ Wed Aug 29, 2007 11:47 pm ] |
Anyone? |
| Author: | dakight [ Thu Aug 30, 2007 5:14 am ] |
http://www.slantsix.org/forum/viewtopic ... unt#123289 Search is your friend. |
| Author: | greasy 225 [ Thu Aug 30, 2007 10:35 am ] |
Not the post I was thinkin but very helpful tho. I was thinkin the mounts were shorter than 2" and they needed to be sectioned down abit. Cool of to the shop now! -Jesse |
| Author: | slantzilla [ Thu Aug 30, 2007 2:22 pm ] |
If you take an old mount out and disassemble it, the idea becomes easy as pie. |
| Author: | 64'4$peed [ Thu Aug 30, 2007 3:05 pm ] |
I did it. just the drivers side. I decided the vibration wasn't worth it. It resonated through the whole car at certain rpms in 5th gear that happened to be ideal cruising rpm's. so I will be changing it out tonight if my rubber ones show up like they R supposed 2. J |
| Author: | greasy 225 [ Thu Aug 30, 2007 6:16 pm ] |
Didnt have an old one to copy. So I went to Kragen bought both the mounts got all my dimentions then returned them(Im such a prick). Thanks for the tips. -Jesse |
| Author: | slantzilla [ Thu Aug 30, 2007 7:09 pm ] |
Quote: Didnt have an old one to copy. So I went to Kragen bought both the mounts got all my dimentions then returned them(Im such a prick). Thanks for the tips.
-Jesse |
