It is currently Fri Nov 27, 2026 12:30 am
 Post subject: master cylinder size
PostPosted: Sat Sep 01, 2007 4:37 pm
i bought a master cylinder awhile back on ebay 1573m. i got i but didn't know i had 9 inch rears at the time. now that the master cylinder's gone bad on the duster i need to change it out. the only thing is the one i have is for 10's all around how much of a difference can this make for the 9 inch rears my front has 10s.
i was trying to hold out until i got all the parts for disks but i cant the brake pedal drops to the floor and i have a hard time stopping so i have to keep the drums on until i have all i need to do the change.
PostPosted: Sat Sep 01, 2007 6:32 pm
Don't worry about it; 9" and 10" drum systems use the same-size master cylinder.
PostPosted: Sun Sep 02, 2007 4:12 am
they look the same but when i look at rockauto and my parts store. the info say's that one is for 9's rears and the other is for 10 in rears.
A-1 CARDONE Part # 101516M
w/Drum Brakes w/Manual Brakes w/9" Rear Brakes
"this is the one i have" A-1 CARDONE Part # 101573M
w/Drum Brakes w/Manual Brakes w/10" Rear Brakes
RAYBESTOS Part # MC36338 {Professional Grade Bore Size=15/16" Number of Ports=2 Primary Outlet Size=9/16x20 Secondary Outlet Size=1/2x20}
Front Drum Brakes..
i really have to change it out soon i cant stop last night i was on the floor with the pedal the back tires were skidding and smoken but i wasn't stopen
PostPosted: Sun Sep 02, 2007 6:27 am
It will fit and work fine. My biggest concern is that it's a Cardon reman... they don't have best reputation for quality.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Sep 02, 2007 6:31 am
Yup, if you have any possibility of getting a different brand (Bendix, Raybestos, EIS, Wagner, United), don't use that Cardone garbage. It'll only cost you money, time, effort and tears.
