| /6 RSA Cuda https://slantsix.org/forum/viewtopic.php?t=24681 |
Page 1 of 2 |
| Author: | 68barracuda [ Wed Aug 29, 2007 3:57 am ] |
| Post subject: | /6 RSA Cuda |
Hi Guys, Well after following the articles on the site and implimenting them I have the following setup 68 RHD FB Barracuda Formula S - over here that means a 170 HP /6 Carter BBD, with High lift cam - do not have the spec - if someone can help? and a 8.8 CR 45mm exhaust TorqueFlite 904 9" Drums all round 13 inch 4.5J Rims Modified with the following: 465 (450?) CFM Holley 4150, vac sec , 51 Primary, 53 Secondary, Silver spring, pink cam in number 1 hole 4BBL manifold looks like a Offenhauser Mopar electronic distributor with GM HEI module 57mm Stainless exhaust through freeflow muffler Extrusion Honed exhaust manifold 14 inch 5.5 J rims Planned Mods 11 Venitilated Discs 10 inch drums with Borg Warner rear end - think might be 8 1/4, at least better than the 7 1/4 in there now - this rear end bolts in but has a 1 1/2 inch extra between the springs and the drums ie. moves the tires outwards Dual master cylinder The above comes from an Austrialian CM Valiant and is being refurbished as we speak Headers - 3 3 - 2 - 1 or 3 3 - 2 Advice please And then the biggie Locally we had what was called Atkinsons powerpack in th 60's Modified head allows for 9.6 CR, ported for increased swirl, bigger valves AND a inlet manifold with 12 inch ramtubes pared 3 3 , each set being fed by a 36DCD7 with a ballance tube between the plennums This was fitted to a Barracuda called the 110 as it was the first one over here to go faster than 110MPH SO Advice tips insults let it rip - have got photos and articles I can email. Regards |
| Author: | slantvaliant [ Wed Aug 29, 2007 6:34 am ] |
Please. post some photos! It sounds like an interesting 'Cuda! |
| Author: | 68barracuda [ Wed Aug 29, 2007 1:28 pm ] |
OK As requested I will put them on my www.valiantproject.co.za website - but we had a server crash so please be patient What would you guys - Doctor Dodge your input would really be appreciated - recommend as far as exhaust system is concerned? Stay with a single 57 mm or go for a dual setup with a balance tube What kind off length the extractor tubes be to optimise torque and power - drivability being important for me - slightly lumpy idle no problem Another question I have at this stage is regarding my jetting, cam, and spring Would going to stiffer spring help improve launching - as it is a bit sluggish of the mark once past 25 to 30 mph it goes like a bat out off hell - have noticed quicker times if a bit off wheel spin - more flow through the carb - is induced ( sand on the road etc) Regards Fanie |
| Author: | 68barracuda [ Wed Aug 29, 2007 1:59 pm ] |
OK so my site will be offline for a day or two, but there is some pics at http://autos.ph.groups.yahoo.com/group/ ... rowse/df22 |
| Author: | 68barracuda [ Wed Aug 29, 2007 2:21 pm ] |
Oh yes A six into one header or a three, three two? |
| Author: | SlantSixDan [ Wed Aug 29, 2007 3:03 pm ] |
No go on the photos...that's a members-only photos page, and Yahoo seem to be having some technical problems right now The South African Mopars are nifty. I don't have a whole bunch of material on them, but I do have some. For the '70-'73 year range, there are three versions of the 225 described in the brochures: •The "Economy Slant Six", which had a 1bbl carburetor, 8.4 compression, advertised at 145 bhp and 215 lb-ft of torque (really familiar and questionable numbers, unchanged in the US from '60 through '72 when the new horsepower rating system came in), •The "Formula S Slant Six", which had a 2bbl carburetor, 8.4 compression, advertised at 170 bhp and 220 lb-ft of torque (not too far off the published rating of 160 bhp for the Australian-market engine with same general specs but probably different ignition distributor and other details) •The "Charger Power Slant Six", which had a 2bbl carburetor, 9.3 compression, advertised at 190 bhp and 230 lb-ft of torque (probably very similar to the engine used in the Australian VF Pacer 225 of 1969, which had published compression of 9.2 and published output of "We're keepin' it a secret") For what it's worth, the Australian 1969 FSM reveals that the 1bbl engines got the 240°-240°-16°-0.395" camshaft, while the 2bbl engines (including the hotter 9.2-compression Pacer engine) got the 244°-244°-26°-0.414" camshaft. The latter became standard equipment in North American slants for the 1971 model year. Don't know if this is at all applicable to the South African "190" engine, but given that the SA-market slant-6 engines were generally sourced from North America rather than Australia, it seems at least reasonably likely. I don't have any RSA FSMs or FPCs (alphabet soup, anyone? Years ago, I had a brief test drive in a 1973 Chrysler Valiant Charger 190 Sports Coupé (quite a mouthful!) which was a South African market RHD '71 Demon with the Charger Power 190 bhp engine. What to do with your exhaust system? Mmmm...interesting question! You haven't got a steering system in your way, and you haven't even got the Australian issue of retaining oil filter access since the South African oil filter was atop the valve cover rather than on the manifold side of the block, so you've got a bunch of wide-open space for whatever headers you would want to put in. Are you planning on buying locally or importing from overseas? Because there's also the Dutra Duals option. |
| Author: | 68barracuda [ Wed Aug 29, 2007 3:25 pm ] |
Yup Yahoo is stuffed at this stage!! The mouthfull got worse, wich is why I am busy with the Valiant Project website - to record info on Valiants over here The early 70's Valiants (Plymouths) over here were all based around the Dodge dart range - more or less We had VIP,Regal And Rebel - as Well as charger Talking of engine specs - the last /6 was produced in 79-80 over here and had a factory 4bbl aluminium manifold - the same one I am using at this stage The reason I am looking at the Weber setup is that it was a factory as well as after market mopar option over here like and I am looking at building a more or less periond correct engine - as far as looks is concerned - internally ....welll...........torque and power woo hooooooo! Dutras would be nice, a set of cliffords as well BUT the exchange rate makes it very expensive R7 to $1 and the import tax bumps it up even higher - so a local companny called TNT (www.tnt.co.za) wiil do the honuors even have tehm ceramic coated inside and out - for an extra $250 they can manufacture a Hyperpack work alike as well - Do you know where I can get hold of one? might be tempted Thanks for the cam specs |
| Author: | SlantSixDan [ Wed Aug 29, 2007 3:40 pm ] |
Quote: The early 70's Valiants (Plymouths) over here were all based around the Dodge dart range - more or less
Well, yeah...the South African line as I've been able to piece it together was kind of an interesting mix of US Dodge Darts (SA Valiant Regal through sometime between '71-'73), US Plymouth Valiants (SA Valiant and/or Valiant Rebel '60 through '68 or so), Australian Valiants (SA Valiant Rebel starting in '69 or so, SA Valiant Regal starting whenever in '71-'73 the Dart bodies were dropped...definitely before '74), US Plymouth Barracudas (same as US except RHD), US Dodge Lancers (SA DeSoto Rebel '61-'63), and various US Dodge and Plymouth B- and C-body cars, minimally modified except for RHD and compliance items such as lighting. As far as I can tell, the Canadian-market "mix and match" cars ('63-'64 Canadian Valiants with US Dart bodies carrying US Valiant front end sheetmetal) were exported in small number to the UK, but not to SA, where RHD American-model Valiants were sold. I do not have any information on whether 111"-wheelbase A-bodies (US Dart) were sold in SA prior to 1968, do you? A friend of mine (owner of the aforementioned Valiant Charger 190 Sports Coupé) has a book on SA Valiants...somewhere. He says he'll scan it in and send it next time he finds it :-\ Quote: Talking of engine specs - the last /6 was produced in 79-80 over here and had a factory 4bbl aluminium manifold - the same one I am using at this stage
Interesting! Can't wait to see pics. Do you have any paper (advertising brochures, factory service manuals, factory parts manuals) for these cars?Quote: The reason I am looking at the Weber setup is that it was a factory as well as after market mopar option over here like and I am looking at building a more or less periond correct engine
I can't wait to see pics of this, too! Quote: a set of cliffords
Yipes. Clifford are a treacherous, unreliable vendor even for those who live in their same state. I cannot imagine anything but tears, acrimony, and big phone bills coming from an effort to buy from them for overseas export! Quote: a local companny called TNT (www.tnt.co.za)
Y'sure about that? The site that comes up is some sort of computer-service firm.Quote: have tehm ceramic coated inside and out - for an extra $250 they can manufacture a Hyperpack work alike as well
Interesting! What kind of a Hyper-Pak workalike are we talking about here...? Tubular headers, cast iron split manifolds, something else?Quote: Do you know where I can get hold of one?
One what?Quote: Thanks for the cam specs
You're welcome. There are many more cam options now than ever there have been before. I'm sure you've got competent cam grinders over there. Spend some time in this thread and this one for ideas.How's the Mopar & Valiant scene in SA these days? I know the cars have an avid following in Australia, but don't know much at all about the hobby in South Africa. |
| Author: | 68barracuda [ Wed Aug 29, 2007 3:58 pm ] |
Quote: Y'sure about that? The site that comes up is some sort of computer-service firm.
Woopshttp://www.tntexhausts.co.za/ProductsMain.html Quote: Interesting! What kind of a Hyper-Pak workalike are we talking about here...? Tubular headers, cast iron split manifolds, something else?
The inlet manifold but made up out off tubular aluminum - tubular mild steel headersQuote: One what?
The hyper Pak inlet manifold - would love to have a cast oneQuote: Interesting! Can't wait to see pics. Do you have any paper (advertising brochures, factory service manuals, factory parts manuals) for these cars?
Yes, Yes and yes...did I miss one? I am one of a group of guys who are trying to get the mopar gang to hook up - so far it is being received well - sll kinds of rarities cropping up Parts availability is improving thanks to local guys that are starting to make replacement parts |
| Author: | slantzilla [ Wed Aug 29, 2007 4:15 pm ] |
Sounds like a neat little car. |
| Author: | 68barracuda [ Wed Aug 29, 2007 10:24 pm ] |
http://www.cardomain.com/ride/2562072 Hey A couple of pics off my other Valiant - not a / but still an A-body will post my Cuda here as well |
| Author: | 68barracuda [ Thu Aug 30, 2007 3:41 am ] |
Quote: http://www.cardomain.com/ride/2562072
http://www.cardomain.com/ride/2864297/1
| Author: | SlantSixDan [ Thu Aug 30, 2007 8:30 am ] |
Sharp-lookin' cars! I like the "VALIANT" lettering across the front (ours said "PLYMOUTH"), and it's fun to look at the engine bay pics of the Barracuda and notice all the unique-to-RSA features. The valve cover mounting of the oil filter, the remote brake booster (can't quite see what kind of setup it is...where's the booster itself mounted?). Also your 2bbl linkage cleanly adapted to operate a 4bbl, etc. Guessing both the front and rear sidemarker lights on the '68 put out amber light, for that was generally the requirement in Commonwealth countries except Canada (in North America, the rear sidemarker light puts out red light, and the front puts out amber.) Do the rear indicators on the '68 flash red or amber? |
| Author: | 68barracuda [ Fri Aug 31, 2007 2:11 am ] |
Hi To answer you Quote: (Can’t quite see what kind of setup it is...where's the booster itself mounted?)
Tandem master cylinder - no booster.....uhm I lie - me old legs bin ye olde boostor sah!!Some were fitted with a remote booster on the same side yours were - dont feel the need though The rhd DOES leave a lot of space for headers and manifold experiments, turbo - Talking of witch - do you guys now the VW Jetta 4 TDI Has a 1.9 liter turbo diesel, with much the same troue and hp peak rpm's as the slant..... Now 1.9 X 2 = 3.8 ....... maybe a twin turbo setup with the twin webers Hope Doug reads this Oh well to continue Quote: Do the rear indicators on the '68 flash red or amber?
Amber all the way - for safety sake I was wondering if I shouldnt rather hook them into the indicator setup - no amber needed here anymore - even though I like it - some sort off reverse relay action to allw them to blink of and on at night and on and off during the day...The cuda's indicators are a bit hidden from the side A bit of extra history These cars were imported in knocked down form from Canada, and assembled by Chrysler in Elsies River Cape Town - at that stage Chrysler here was run by Atkinson’s - the guys who brought us the dual weber setup |
| Author: | SlantSixDan [ Fri Aug 31, 2007 10:05 am ] |
Quote: Quote: Do the rear indicators on the '68 flash red or amber?
Amber all the wayQuote: I was wondering if I shouldnt rather hook them into the indicator setup
Yup. You can have them continue to operate as sidemarkers and flash with the indicators, day or night. This is easier to accomplish on '70+ cars with 2-wire sidemarkers, but it's not too difficult on '68s with 1-wire sidemarkers. First we need to clarify terminology: Commonwealth English calls "sidelights" what North Americans call "parking lights" front and "tail lights" rear, and Europeans call "position lights". These are the low intensity lights, red on the rear and white or amber on the front, that come on with the first click of the headlamp switch. The "sidelights" term can throw a wrench in the works, because they're not the same as the "sidemarker lights", which are the round ones that are on the sides of the car and also come on with the first click of the headlamp switch. I'll call the front and rear lamps "position lamps" here. Use an ordinary Normally Open (SPST) relay with no diode across its coil, and wire it up as follows: #85: To front or rear position lamp feed #86: To front or rear indicator feed #87: To front or rear sidemarker light #30: Via fuse to always-live +12v If you're keeping the rear sidemarkers amber, you could do this mod to the fronts and rears. If you're installing US red rear sidemarker lenses, do the mod only to the fronts. You need one relay for left and one relay for right. Depending on which is most convenient for you in terms of wiring effort, you can either put in one relay for each of the four sidemarkers, or you can put in one for both lefts and one for both rights. With this setup, the sidemarkers will operate as they presently do (steady burning with the position lamps or headlamps on). Those that are relayed will flash in phase with the indicators when the position or headlamps are off, and will flash in opposite-phase with the indicators when the position or headlamps are on. Quote: These cars were imported in knocked down form from Canada
H'mmmm...my '68 Canadian FPC contains some but not all of the export P/Ns. It's got export low-compression engines and parts, export 2bbl induction components, export RHD suspension, steering, engine, dash and interior components, export mile and kilometre speedometers...but it's silent on the "V A L I A N T" lettering across the front of the RSA cars, doesn't list any different lighting components, doesn't contain the rocker cover oil filter mounting setup, etc. :-\ I'm guessing there were RSA-printed parts catalogues. Quote: Chrysler here was run by Atkinson’s - the guys who brought us the dual weber setup
Cool! |
| Page 1 of 2 | All times are UTC-08:00 |
