| Why doesn't my horn work? https://slantsix.org/forum/viewtopic.php?t=24688 |
| Author: | Daddiojoe [ Wed Aug 29, 2007 10:59 am ] |
| Post subject: | Why doesn't my horn work? |
I need to get my truck through inspection, so I'm finally addressing my horn problem. I get a buzzing at the Painless Wiring replacement fusebox, but no honk. So I try to make sure that the horn itself works by jumping it to the battery. It doesn't work, so I get a new horn. This horn doesn't honk when attached directly to the battery either. How come? Do I need a relay? I thought that there was a relay in the Painless fusebox--do I need another one? Thanks, Joe |
| Author: | KBB_of_TMC [ Wed Aug 29, 2007 11:53 am ] |
Make sure the horn is properly grounded. Most US horns have a grounded case to complete the circuit; many foriegn horns are floating and one of the 2 pins must be grounded for them to work. I've seen brand new universal replacements horns from the same vendor (F-something) with identical model numbers on the shelf with with some of one kind and some of the other. |
| Author: | SlantSixDan [ Wed Aug 29, 2007 1:45 pm ] |
Their name is ironic, given the degree and frequency of the pain caused by "painless" wiring's stuff. If you're getting a buzzing at the fusebox, it probably means your horn relay (installed there) is faulty. |
| Author: | Daddiojoe [ Wed Aug 29, 2007 5:29 pm ] |
Thanks for the replies, guys. I'll check the grounding of the horn. Anyone have a part number for a nice generic horn relay? Joe |
| Author: | SlantSixDan [ Wed Aug 29, 2007 7:02 pm ] |
If Painless Wiring are still using GM-style fuseboxes, the relay you need is probably something like a Standard HR151 is probably what's called for:
