| EGR Block off plate https://slantsix.org/forum/viewtopic.php?t=24690 |
| Author: | Aggressive Ted [ Wed Aug 29, 2007 1:13 pm ] |
| Post subject: | EGR Block off plate |
Who sells EGR block off plates? Checked the parts for sale section, none to be found? I would like to purchase one plate and one gasket for my engine. Thanks, |
| Author: | Matt Cramer [ Wed Aug 29, 2007 1:15 pm ] |
Usually, the procedure for an EGR blockoff on a slant six is simply to remove the hose from the vacuum diaphragm and cap whatever the other end leads to... |
| Author: | Aggressive Ted [ Wed Aug 29, 2007 1:24 pm ] |
Done that........I want to make sure it is not partially stuck in the on position. |
| Author: | SlantSixDan [ Wed Aug 29, 2007 2:31 pm ] |
Dealer item, p/n 3671 447, used with standard EGR valve gasket p/n 4173 167. |
| Author: | mrhite65 [ Wed Aug 29, 2007 2:58 pm ] |
Or make your own.
| Author: | SlantSixDan [ Wed Aug 29, 2007 3:05 pm ] |
Recommend using 1/4" (0.250") material, rather than 1/8" (0.125") for flange rigidity and sealing. |
