It is currently Sun Nov 22, 2026 5:40 pm
 Post subject: putting motor together
PostPosted: Tue Aug 28, 2007 10:40 am
looking in my manual, I do not see the placement or which way the bearings go on the main and pistons, do the bearing divots go on the same side of each other or opposite of each other. this of course is the placement of the caps, bearing can only go in one way on the caps. already lost one motor. and would napa rent the tool for the cam bearings?
Money and time burnin on both ends....
PostPosted: Tue Aug 28, 2007 2:29 pm
Bearing tabs go on the same side on rods and mains.
No idea if NAPA will have a cam bearing tool.
Welcome to the board. :D
PostPosted: Thu Aug 30, 2007 7:53 am
well that explains it then, thank you......been too long from being under the hood.
Users browsing this forum: Google [Bot] and 8 guests
