It is currently Mon May 11, 2026 12:39 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: BBS
PostPosted: Fri Jul 27, 2001 5:59 am
Just rebuilt my BBS-4286S. Run's great, but when braking into a corner ~20mph (ie. yeild)
The engine will stumble, and stall. I restart on a roll in neutral an rev it up to clear it out and it's fine. I had the same problem before rebuild.
Any info is appreciated.
PS. The Car is a 67' Dart GT conv. with 225.
Shop manual says this carb came on the 170.
Should I have a different carb? What's best? Thanks.
 Post subject: Re: BBS Problem
PostPosted: Fri Jul 27, 2001 9:17 pm
: Just rebuilt my BBS-4286S. Run's great, but
: when braking into a corner ~20mph (ie.
: yeild)
: The engine will stumble, and stall. I restart
: on a roll in neutral an rev it up to clear
: it out and it's fine. I had the same problem
: before rebuild.
: Any info is appreciated.
: PS. The Car is a 67' Dart GT conv. with 225.
: Shop manual says this carb came on the 170.
: Should I have a different carb? What's best?
The float level may be a bit high try lowering it, like 1/8 inch (a lot but it will show you if that is the cause). I lower my float level untill I get some "starving" on high "G" corning, then I raise the level up a bit to get rid of that.
PostPosted: Sat Jul 28, 2001 12:50 pm
: The float level may be a bit high try lowering
: it, like 1/8 inch (a lot but it will show
: you if that is the cause). I lower my float
: level untill I get some "starving"
: on high "G" corning, then I raise
: the level up a bit to get rid of that.
: DD
The float may also be low, causing starving in the corners. If lowering doesn't do it, try raising it.
Chuck
webmaster@omnipages.com
 Post subject: Re: BBS Problem Solved
PostPosted: Sat Jul 28, 2001 4:34 pm
: I tried some more driving techinques, and it does it on a hard, straight stop. Bowls in front, so fuel is moving away. I think to low.
Thanks guys
PS. Is this correct carb for stock 225, or am I better
off with a different with something else? Thansk
