It is currently Sat Nov 21, 2026 7:34 am
 Post subject: Electric Choke
PostPosted: Wed Oct 27, 2010 9:41 am
I am new to most of this stuff, so be kind. What is the advantages/disadvantages of using an electronic choke? My original 1 bbl intake/carb had the regular choke on it, but as I near completion of the Super Six Swap, I noted the electronic choke on the intake. Your thoughts would be appreciated. Thank you.
PostPosted: Sat Oct 30, 2010 4:20 am
No sure if there is a disadvantage of electric choke. It does the work by itself. or you can put a cable on your carb and do the function yourself.
I would hook up the elec choke. its only one wire to a keyed powersource. I have mine connected to the ballistic resister. I am no pro either.
JEFF
71 DART SWINGER
225
Users browsing this forum: Amazon [Bot], Google [Bot] and 8 guests
