It is currently Sat Nov 21, 2026 2:13 pm
 Post subject: Exhaust Spacer
PostPosted: Thu Sep 06, 2007 6:58 pm
As some of you know I am in the process of putting a 225 in my 66 Valiant, as a replacement for the slightly toastie 170 that had to come out.
My question is about the exhaust pipe. Since the head seems to be about an inch higher on the 225 I am assuming the exhaust header pipe will be about in inch low (to keep the pipe in the same location).
I was thinking of fashioning a spacer out of stee or something that would make up the difference there.
Am I trying to re-invent the wheel here. Is there something commercially available that doesn't cost $50 :lol:
The other thought I had was just cutting the flange off of two or three old header pipes from the junk yard and welding them together.
Any thoughts?
Chris
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Thu Sep 06, 2007 7:20 pm
Cut the pipe and weld in a small section.
PostPosted: Thu Sep 06, 2007 7:37 pm
A stack of exhaust gaskets...............
:idea:
:shock:
:roll:
:wink:
PostPosted: Thu Sep 06, 2007 9:14 pm
The spacer idea works well if you can find a way to do it cheaply and effectively.
PostPosted: Thu Sep 06, 2007 9:26 pm
And this is why two heads are better than one!!!
Josh if I decide the 170 ain't going back in there at some point, that is exactly what i am going to do :)
Users browsing this forum: Bing [Bot] and 11 guests
