Manifold
https://slantsix.org/forum/viewtopic.php?t=24812
Page 1 of 1
Author:  HeavyBreather [ Thu Sep 06, 2007 8:14 pm ]
Post subject:  Manifold
Since fuel injectors are going to be used for fuel supply does it matter whether a 1barrel or 2barrel or 4barrel intake is used?
Author:  mpgmike [ Thu Sep 06, 2007 9:42 pm ]
Maybe. The factory 1 and 2 bbls have similar runner length and cross section. You'd have to machine the tb inlet to match your choice. If you go with a 4 bbl, the runners will most likely be larger in diameter. Of course, availability would have a lot to do with choice as well.
Mike
Author:  Matt Cramer [ Fri Sep 07, 2007 9:07 am ]
Well, the 1 bbl would need a bit of machining to fit a decent sized throttle body on it. I take it this is port injection, not a TBI?
Author:  Rob64GT [ Fri Sep 07, 2007 10:47 am ]
I used a new Clifford manifold, it has injector bosses cast on the manifold and mounts for a fuel rail. It was fairly easy to make adapter for a throttle body.
Author:  HeavyBreather [ Fri Sep 07, 2007 3:21 pm ]
If I use the clifford intake is there any way I can get around useing the headers because I dont want headers.
Author:  Pierre [ Fri Sep 07, 2007 5:30 pm ]
You don't have to use headers, but you can't use the stock exhaust manifold. The clifford intake has a water passage on the bottom of the plenum that will hit the stock exhaust.
Author:  Sam Powell [ Sat Sep 08, 2007 5:05 am ]
Dutra duals are what I used with the Clifford intake, but some clearance work was needed to get the rear flange to fit with a mini-starter. It was not hard, but took time, and a mini starter was required which is an added expense. This entire project was quite expensive by the time it was all done. I can't remember exactly, but I think I paid about $300 for the Dutra duals, and around $200 for the intake from Clifford, and $120 for the starter. And then there was custom exhaust work. I paid $200 for prebent 340 exhaust pipes and then about $200 for custom head pipes to be bent. There you go; over $1000 for intake and exhaust before I spent a dime on the EFI or turbo stuff.
Sam
Author:  Rug_Trucker [ Sun Sep 09, 2007 6:48 am ]
You are running Dutra's feeding the turbo?
Author:  MaxSafari [ Mon Sep 10, 2007 4:08 am ]
Hi,I used a two barrel manifold with a single 65mm throttle body.I made a alloy 3/8 plate with counter sunk cap screws into the manifold.If its mounted with the spindle across (east/west) the linkage is easy to build.
