It is currently Tue Jun 02, 2026 6:27 pm
 Post subject: Easy HEI Question
PostPosted: Fri Sep 07, 2007 12:05 pm
Before i start changing over the to HEI this weekend. It looks like there is 2 wires to the Positive side of the coil and 1 to the negative side. One each from the module plus one more to the positive side terminal. That one coming from the old/spliced wire from the Ballast resistor?
Is this correct?
PostPosted: Fri Sep 07, 2007 12:56 pm
The ballast resistor gets removed when swapping to HEI. See see HEI upgrade instructions.
PostPosted: Fri Sep 07, 2007 1:50 pm
Got that part, but insn't there a wire from the spliced ballest resister (removed) wiring going to the Positive post on the coil?. I am looking at the diagram from duster318.freesavers.com webpage that 2 wires go to the positive coil post, one from the old ballost resister wiring?
PostPosted: Fri Sep 07, 2007 2:22 pm
Ah, I misunderstood your question. Answer is yes.
PostPosted: Fri Sep 07, 2007 2:46 pm
No problem. I is not so goood at dis engleesh. Just wanted to make sure i did it right, the first time. Thanks
Users browsing this forum: Ahrefs [Bot] and 3 guests
