| cecil county drags https://slantsix.org/forum/viewtopic.php?t=2484 |
| Author: | andrew wagner [ Sun Jul 29, 2001 8:01 am ] |
| Post subject: | cecil county drags |
I was down at cecil county drag way on saturday here's how I did! 60ft 1/8 mph 1/4 mph 2.066 9.54 70.76 15.12 87.85 2.08 9.66 70.12 15.29 86.97 2.16 9.77 69.97 15.41 86.83 I was very pleased with the car it run smooth. The 15.12 was unexpected I was thinking about 15.4 or 15.5. before I went down I jetted the carb up one # to a 67. I must be starving it a little. for anyone that does not know, I am running a stock slant six 225 with a to3 turbo from a 2.5 four banger, 3" exhaust,four barrel holley,and a chome ecu with msd coil and timing control. andrew wagner |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Jul 29, 2001 10:37 am ] |
| Post subject: | Re: & Turbo SL6 Results |
Way to go Andrew! Take a "stock" 225 SL6, add a TO3 turbo and Holley 4 BBL to "feed-it" and run low 15's, I like it! What rear gear ratio are you running? any Posi back there? I would think that traction is starting to become an issue with the car but I'm sure your "blowing some minds" with this deal. Time to give the carb. even more jet??, can you say high 14's?? DD Quote:
: I was down at cecil county drag way on saturday : here's how I did! : 60ft 1/8 mph 1/4 mph : 2.066 9.54 70.76 15.12 87.85 : 2.08 9.66 70.12 15.29 86.97 : 2.16 9.77 69.97 15.41 86.83 : : I was very pleased with the car it run smooth. : The 15.12 was unexpected I was thinking : about 15.4 or 15.5. before I went down I : jetted the carb up one # to a 67. I must be : starving it a little. for anyone that does : not know, I am running a stock slant six 225 : with a to3 turbo from a 2.5 four banger, : 3" exhaust,four barrel holley,and a : chome ecu with msd coil and timing control. : : andrew wagner |
| Author: | andrew wagner [ Sun Jul 29, 2001 4:48 pm ] |
hey doug I am putting a 650 dp on for next saturday. I run a 8 3/4 rear with 3.55 and a posi. As for traction it is spinning of the line but not more then once around then it hooks. I also put 235 60 14s on to help. when I ran the 15.12 it was at 7 psi.I let you guys know on sunday if I get in the 14s. andrew wagner Quote:
: Way to go Andrew!
: Take a "stock" 225 SL6, add a TO3 : turbo and Holley 4 BBL to : "feed-it" and run low 15's, I like : it! : What rear gear ratio are you running? any Posi : back there? I would think that traction is : starting to become an issue with the car but : I'm sure your "blowing some minds" : with this deal. : Time to give the carb. even more jet??, can you : say high 14's?? : DD |
| Author: | dschumers [ Sun Jul 29, 2001 6:28 pm ] |
: hey doug : I am putting a 650 dp on for next saturday. I : run a 8 3/4 rear with 3.55 and a posi. As : for traction it is spinning of the line but : not more then once around then it hooks. I : also put 235 60 14s on to help. when I ran : the 15.12 it was at 7 psi.I let you guys : know on sunday if I get in the 14s. : : andrew wagner That's great Andrew! Keep those results coming. Dennis aschumers@aol.com |
| Author: | S/anted [ Sun Jul 29, 2001 7:39 pm ] |
| Post subject: | Re: cecil county drags |
: I was down at cecil county drag way on saturday : here's how I did! : 60ft 1/8 mph 1/4 mph : 2.066 9.54 70.76 15.12 87.85 : 2.08 9.66 70.12 15.29 86.97 : 2.16 9.77 69.97 15.41 86.83 : : I was very pleased with the car it run smooth. : The 15.12 was unexpected I was thinking : about 15.4 or 15.5. before I went down I : jetted the carb up one # to a 67. I must be : starving it a little. for anyone that does : not know, I am running a stock slant six 225 : with a to3 turbo from a 2.5 four banger, : 3" exhaust,four barrel holley,and a : chome ecu with msd coil and timing control. : : andrew wagner VERY COOL!!! Keep up the great work. Was this with your in house fabed intake too? Mike msimpson@millenicom.com |
| Author: | Will [ Sun Jul 29, 2001 11:21 pm ] |
| Post subject: | How far from Buds Creek |
How far are you from Buds Creek? I may race there sat. Will Quote:
: hey doug : I am putting a 650 dp on for next saturday. I : run a 8 3/4 rear with 3.55 and a posi. As : for traction it is spinning of the line but : not more then once around then it hooks. I : also put 235 60 14s on to help. when I ran : the 15.12 it was at 7 psi.I let you guys : know on sunday if I get in the 14s. : : andrew wagner slantsix@netzero.net |
| Author: | andrew wagner [ Mon Jul 30, 2001 10:20 pm ] |
| Post subject: | Re: How far from Buds Creek |
where is bud creek? asndrew wagner Quote:
: How far are you from Buds Creek? I may race : there sat. : : Will |
| Author: | Charlie Schmid [ Tue Jul 31, 2001 6:44 am ] |
Isn't Cecil County Dragway in Budds Creek, Maryland? I raced there once about 1965. Charlie Quote:
: : where is bud creek? : : asndrew wagner flturbo6@aol.com |
| Author: | Dart270 [ Tue Jul 31, 2001 4:57 pm ] |
: That's great Andrew! Keep those results coming. : Dennis Congrats Andrew. Keep up the good forced induction... Lou madsenl@caltech.edu |
| Author: | Will [ Wed Aug 01, 2001 12:15 am ] |
: where is bud creek? : : asndrew wagner south Maryland. home of Maryland international dragway. Doesnt matter, not going this weekend. See youall at Wilksboro. Will slantsix@netzero.net |
