| K Frame bolt torque https://slantsix.org/forum/viewtopic.php?t=24854 |
| Author: | 73NorthernDuster [ Sun Sep 09, 2007 9:58 pm ] |
| Post subject: | K Frame bolt torque |
Anyone know the answer to this one. Can't find the spec listed in the fsm. I dropped the k frame and rebuilt everything on my 73 Duster. Putting it all back together but I cant find the torque spec for the four bolts that hold the k frame to the frame rails. They are a pretty big bolt so Iam thinking between 75 and 100 ft lbs at least but if someone knows the exact spec it would be appreciated. Thanks Brent 73 NorthernDuster |
| Author: | walpolla [ Mon Sep 10, 2007 2:33 am ] |
TIGHT. never had a problem with them coming loose. and that is with a lot of enthusiastic use way and above a normal road car. there probably is a specified torque somewhere,but the size of the bolts is "agricultural" to say the least,so old farming technique -" make sure them bolts is tight as you can get 'em son." always worked for me. regards,Rod |
| Author: | slantasaurus [ Tue Sep 11, 2007 9:07 pm ] |
I use German torque values....goodentite. |
| Author: | Sam Powell [ Wed Sep 12, 2007 4:37 am ] |
Check em again after you have driven the car a bit and things have settled. This is good advice for most things in the supension. Sam |
| Author: | 73NorthernDuster [ Wed Sep 12, 2007 9:00 pm ] |
| Post subject: | Thanks |
Thanks for all the input I guess I'll pull on them till my back gives out. Then it will be time for a beer. Cheers |
| Author: | Walter Lee Jackson [ Thu Sep 13, 2007 11:52 pm ] |
150 foot-pounds according to the Field Service Manual for my 1963 Dodge Dart GT. An A body is an A body in this regard, I suspect, whether a 63 or a 73. Hope this helps. --Walt Jackson |
