| Getting the timing gears off!!! https://slantsix.org/forum/viewtopic.php?t=24938 |
| Author: | ValiantOne [ Sun Sep 16, 2007 3:05 pm ] |
| Post subject: | Getting the timing gears off!!! |
Hey All, I am trying to get the timing gear off the crank, and having quite a time with it. Stuck, stuck, stuck. I got it to move about 1/4 inch and that is it! I had to put two cold chisels 180 degrees from eachother and tap them downward between the gear and the block. I moved the gear away from the block the width of the cold chisels, but now I am stuck. Is there some secret to this? Sheesh I wish my FSM was here arlready as I am wondering if I am missing some special 1979 ONLY TIMING GEAR REMOVER CHRYSLER PART NUMBER blah, blah, blah............ Thanks for any help guys. C |
| Author: | dakight [ Sun Sep 16, 2007 3:16 pm ] |
You need a gear puller. Commonly they have 3 legs that hook behind the gear and a central screw that presses against the crank. Sometimes a little heat helps. |
| Author: | ValiantOne [ Sun Sep 16, 2007 5:01 pm ] |
Figures I thought about putting a torch on it but figured I'd ask you guys first. Thanks! |
| Author: | DusterIdiot [ Sun Sep 16, 2007 8:36 pm ] |
| Post subject: | If it's tight... |
Quote: I thought about putting a torch on it but figured I'd ask you guys first.
You can put a torch on it if it's really tight, but the gear puller is the key... -D.Idiot |
| Author: | Dart270 [ Mon Sep 17, 2007 5:56 am ] |
I got a loaner puller from Advance Auto last time I did this (free). They are about $50 for the Advance cheapy one, which worked fine, or about $200 for a name brand Snap On or similar. Lou |
| Author: | ValiantOne [ Mon Sep 17, 2007 6:14 am ] |
Quote: I got a loaner puller from Advance Auto last time I did this (free). They are about $50 for the Advance cheapy one, which worked fine, or about $200 for a name brand Snap On or similar.
Yikes! A free loaner is sounding pretty good at those prices.Lou For the 2 times I would use this every 10 years, I am thinking $30 from harbor freight will suffice |
| Author: | ValiantOne [ Mon Sep 17, 2007 12:28 pm ] |
Hey guys, the 4" puller at Advance auto was only $22 so I went ahead and got it. I must have had the gear right on the cusp of coming off 'cause I turned the wrench one time and the gear popped off anyhow thanks for putting up with all my noob stupidity |
| Author: | dakight [ Mon Sep 17, 2007 1:43 pm ] |
The one I have is a WalMart El-Cheapo that I've had for at least 30 years. It's virtually identical to this $12.99 unit from Harbor Freight. http://www.harborfreight.com/cpi/ctaf/d ... mber=45977 |
