Slant Six Forum https://slantsix.org/forum/ |
Looking for a set of Dutra Duals *PIC* https://slantsix.org/forum/viewtopic.php?t=2494 |
Author: | Vito [ Tue Jul 31, 2001 8:18 am ] |
Post subject: | Looking for a set of Dutra Duals *PIC* |
I am looking for a set of Dutra Duals for my 69 Valiant Signet. Email me if you would like to sell a set. I am in Concord CA 94518. <A HREF="mailto:vitod@compumailinc.com">vitod@compumailinc.com</A> http://vito.addr.com/Valiant/ ![]() vitod@compumailinc.com |
Author: | GTS225 [ Tue Jul 31, 2001 11:50 am ] |
Post subject: | Speaking of Duals...Doug? |
Doug, I don't recall seeing anything about weight of your manifolds. I'm wondering if there's any weight savings, using both Dutra front and rear, as compared to stock exhaust manifold. Roger GTS225@aol.com |
Author: | Vito [ Tue Jul 31, 2001 12:10 pm ] |
Post subject: | Re: Speaking of Duals...Doug? |
Should weigh slightly more than a stock manifold I am guessing. Since it has another exhaust outlit casted on to the manifold. Im thinking around 5 pounds more sound right? But with benifit from opening up the exhaust I would think the added wieght is no biggie? I also have a question on how it sounds Doug. A guy at a local show told me it sounds great gives the 6 a nice clapping sound just like an 8. Is this true? Right now I am running a stock exhaust manifold going into a Y splitter to create dual exhaust with 2 glass pack mufflers. It sounds nice and deep but more like a drone sound. I am looking for more of a clapping sound. SO anyone got an extra set for sale? Quote:
: : Doug, I don't recall seeing anything about : weight of your manifolds. I'm wondering if : there's any weight savings, using both Dutra : front and rear, as compared to stock exhaust : manifold. : : Roger vitod@compumailinc.com |
Author: | Doctor Dodge (Doug Dutra) [ Tue Jul 31, 2001 11:51 pm ] |
Post subject: | Re: Weight of Dutra Dual Exhaust Manifolds |
: Doug, I don't recall seeing anything about : weight of your manifolds. I'm wondering if : there's any weight savings, using both Dutra : front and rear, as compared to stock exhaust : manifold. Truth is that these are thick-wall and pretty heavy, 16 lbs each last time I checked. Needless to say that I wanted my manifolds to last longer then the SL6 engine itself! DD |
Author: | Wesley A. Moeller [ Wed Aug 01, 2001 6:59 am ] |
: Doug, I don't recall seeing anything about : weight of your manifolds. I'm wondering if : there's any weight savings, using both Dutra : front and rear, as compared to stock exhaust : manifold. : : Roger I have a Dutra casting on the front three cylinders, and a modified stock manifold on the rear three. I don't know how much the weight of the Dutra casting is, if its more or less than the modified factory manifol, but I don't think its a big difference. I think the Dutra casting would flow a litle better. I've been thinking of getting another Dutra casting for the rear three cylinders of my slant. The modified factory manifold is okay, but honestly, I think a pair of Dutra manifolds would look cooler. I would lose carb heat, but here in Texas, its hot most of the time. I'll post if and when I get a second Dutra manifold. Wes '78 Volare wes.moeller@compaq.com |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
