It is currently Sat May 23, 2026 6:06 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Tue Jul 31, 2001 8:18 am
I am looking for a set of Dutra Duals for my 69 Valiant Signet. Email me if you would like to sell a set. I am in Concord CA 94518.
<A HREF="mailto:vitod@compumailinc.com">vitod@compumailinc.com</A>
http://vito.addr.com/Valiant/
PostPosted: Tue Jul 31, 2001 11:50 am
Doug, I don't recall seeing anything about weight of your manifolds. I'm wondering if there's any weight savings, using both Dutra front and rear, as compared to stock exhaust manifold.
Roger
GTS225@aol.com
PostPosted: Tue Jul 31, 2001 12:10 pm
Should weigh slightly more than a stock manifold I am guessing. Since it has another exhaust outlit casted on to the manifold. Im thinking around 5 pounds more sound right? But with benifit from opening up the exhaust I would think the added wieght is no biggie?
I also have a question on how it sounds Doug. A guy at a local show told me it sounds great gives the 6 a nice clapping sound just like an 8. Is this true? Right now I am running a stock exhaust manifold going into a Y splitter to create dual exhaust with 2 glass pack mufflers. It sounds nice and deep but more like a drone sound. I am looking for more of a clapping sound.
SO anyone got an extra set for sale?
: Doug, I don't recall seeing anything about
: weight of your manifolds. I'm wondering if
: there's any weight savings, using both Dutra
: front and rear, as compared to stock exhaust
: manifold.
: Roger
PostPosted: Tue Jul 31, 2001 11:51 pm
: manifold.
Truth is that these are thick-wall and pretty heavy, 16 lbs each last time I checked. Needless to say that I wanted my manifolds to last longer then the SL6 engine itself!
PostPosted: Wed Aug 01, 2001 6:59 am
: manifold.
: Roger
I have a Dutra casting on the front three cylinders, and a modified stock manifold on the rear three. I don't know how much the weight of the Dutra casting is, if its more or less than the modified factory manifol, but I don't think its a big difference. I think the Dutra casting would flow a litle better. I've been thinking of getting another Dutra casting for the rear three cylinders of my slant. The modified factory manifold is okay, but honestly, I think a pair of Dutra manifolds would look cooler. I would lose carb heat, but here in Texas, its hot most of the time. I'll post if and when I get a second Dutra manifold.
Wes '78 Volare
wes.moeller@compaq.com
