It is currently Wed Nov 18, 2026 1:38 am
 Post subject: NGK UR4 or UR5
PostPosted: Wed Sep 19, 2007 4:25 am
I would like to try some of the NGK UR series for my peanut head SL6. I have a mild build-up (see below), but I don't want to buy two sets of spark plugs to find out which ones I need. The Champion RV12YC's work fine, just want to see if there is a difference.
So is the recommendation UR4 or UR5?
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Sep 19, 2007 5:28 am
The difference between them is heat range. The 4 is hotter, and the 5 is cooler. Me, I would probably pick the UR5 or maybe even try a slightly colder UR6 to start with for extra ping-resistance, unless the engine tends to foul spark plugs, in which case I'd go UR5 or UR4.
PostPosted: Wed Sep 19, 2007 6:14 am
I have used GR4, GR45, and GR5 on my 64 motor (10.5:1 comp, yadda yadda). Works fine. I think I saw a slight drop in accel with GR5s, but no diff with GR45s. These are drool-tube plugs, but assumedly heat range is same.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 4 guests
