| Opinion, which Piston & rod combo is better? https://slantsix.org/forum/viewtopic.php?t=25000 |
| Author: | Crazy Dart [ Wed Sep 19, 2007 11:17 am ] |
| Post subject: | Opinion, which Piston & rod combo is better? |
For the 225 Slant six for 1/8th mile drag racing... The 198 rod with a 2.2L forged piston or the 225 rod with standard piston? |
| Author: | Doc [ Wed Sep 19, 2007 4:48 pm ] |
| Post subject: | Re: Opinion, which Poston & rod combo is better? |
Quote: For the 225 Slant six for 1/8th mile drag racing...
The 198 con rod with 2.2 piston / rings is a much lighter assembly, has less ring/piston friction and the 7 inch long con rod gives you a better rod ratio. A "long rod" 225 SL6 will make more power then a conventional 225... that is why the racer's use this combination.The 198 rod with a 2.2L forged piston or the 225 rod with standard piston? The downside... 198 con rods and 2.2 forged pistons are hard to get these days. DD |
| Author: | Crazy Dart [ Wed Sep 19, 2007 8:04 pm ] |
