| Need help finishing shopping list for 72 to 73 uca swap https://slantsix.org/forum/viewtopic.php?t=25034 |
| Author: | radarsonwheels [ Fri Sep 21, 2007 9:13 pm ] |
| Post subject: | Need help finishing shopping list for 72 to 73 uca swap |
I want to rebuild my '72 demon front suspension and brakes cheap. I just went from drum to disk on my '73 swinger and I have lots of leftover parts because I did the drums over on the 73 before I went to discs. 73 Parts I have and want to swap to the '72: -73 UCAs with newish balljoints, will get moog bushings -'73 10"x2.5" drum knuckles, sbp, with good wheel cyls, hoses, and new drums Parts I am unsure of interchange: I have spare '73 LCAs, but they need sway bar brackets. Will '72 LCAs take '73 balljoint assembly? will '72 balljoint take my '73 knuckle? so do I: -use 72 LCA, 73LBJ? -use 73 LCA , 73LBJ? -use 72 LCA, 72LBJ? I want to buy everything from rockauto or autozone or someplace with a thin profit margin on moog stuff Thanks |
| Author: | sandy in BC [ Sat Sep 22, 2007 7:07 am ] |
You can just leave the 72 LCA right where it is....they interchange. |
| Author: | radarsonwheels [ Sun Sep 23, 2007 12:47 am ] |
| Post subject: | Thanks |
I see lots of info around the web on the disc swap, but I didn't know about the '72 to '73 drum swap (with the possibility of a disc swap later easy) as far as the LCAs go. I got worried when rockauto offered different part numbers for 72 and 73. Kevin |
