| Hood springs and door hinges https://slantsix.org/forum/viewtopic.php?t=25042 |
| Author: | Jopapa [ Sat Sep 22, 2007 1:53 pm ] |
| Post subject: | Hood springs and door hinges |
Well I pulled my driver's side door and fender off just now, and surprisingly, the spring and its mounting posts aren't broken. So now that leaves the question of: how the deuce do I get the hooked portion of the coil spring back on the post that holds the tension on it? The thing's pretty stout, and even with huge channel-loks I can't pull the thing over far enough. Also, for when I put my door back on, how do I properly ajust it so that it'll close properly? I can see that the hinges adjust where they bolt to the door, but which one to I position and in what direction do I do it to correctly align the door? |
