It is currently Mon Nov 16, 2026 10:28 pm
 Post subject: valve cover gasket
PostPosted: Fri Sep 21, 2007 10:37 am
Hi,
What is the best valve cover gasket to use with the stock stamped steel valve cover, my car is a '72 Plymouth Valiant w/225...thanks, Nico
PostPosted: Fri Sep 21, 2007 10:41 am
personally I like the rubber, some swear by the cork, some swear by the rubber. I don't think it makes that much of a difference. But I only use fel-pro or mopar gaskets & I like the rubber for the purpose of reusing it for when adjusting valves
PostPosted: Fri Sep 21, 2007 11:26 am
Definitely rubber, IME&O. Fel-Pro VS12680R.
PostPosted: Fri Sep 21, 2007 4:43 pm
My preferance is cork.
PostPosted: Fri Sep 21, 2007 4:52 pm
rubber baby buggy bumpers
:roll:
PostPosted: Fri Sep 21, 2007 5:00 pm
Tastes filling!
Less great!
 Post subject: gasket
PostPosted: Fri Sep 21, 2007 5:06 pm
How about a cork/ rubber gasket ? that's for us guys that can't make a decision.
PostPosted: Fri Sep 21, 2007 8:33 pm
Thanks guys! I couldn't ask for a better answer both intelligent and humorous...i'm going to the parts store tomorrow to p/u one of these and a carb base gasket felpro 60125...car is getting closer and closer to being a road worthy daily driver. Thanks again! nico
PostPosted: Fri Sep 21, 2007 8:55 pm
Biggest thing whether you choose cork or rubber is to not tighten it too tight. Too tight will cut the gasket and make a leak.
I use whatever happens to be on the rack when I look. :lol:
 Post subject: fasteners
PostPosted: Sat Sep 22, 2007 7:12 pm
Just as important as the gasket are the fasteners. I have found that many 80s slants came with special triangular VC hold downs integral with the bolt. These fit the earlier covers really well and help spread out the clamping force. The v-8 ones that you can buy in the parts store don't fit properly. So next time you're in the yard go look for 'em in a slant van or truck. I have had stellar results!
. . . there was good sport at his making.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 15 guests
