| Shock Stud - Repair or Replace? https://slantsix.org/forum/viewtopic.php?t=25049 |
| Author: | Family Scamp [ Sun Sep 23, 2007 6:32 am ] |
| Post subject: | Shock Stud - Repair or Replace? |
My question concerns a broken shock stud on a 1973 ply scamp 225. The broken stud is the lower rear. Actually the first ¼ inch or so of the threads are broken. I can get the rear washer and shock over the stud but not the front washer and still be able to put the nut on. My questions are: 1) Does anyone have any suggestions on how I can use the current stud? Is there a way to extend the stud? Would a supper thin and strong washer be an option? 2) How is the stud replaced? Does this stud thread into the plate? If so where can I find a replacement? Or is the stud part of the plate and therefore I have to replace the entire plate? Where can I find a plate? Thanks Bruce |
| Author: | slantzilla [ Sun Sep 23, 2007 7:01 am ] |
IIRC, those studs are welded into the plate. You can cut them off, drill a hole through the plate, and install a new stud. You can get new studs at Pep Boys or Autozone, etc. in the 'HELP' section. |
| Author: | tophat [ Sun Sep 23, 2007 6:10 pm ] |
That part is held on by the rear end U bolts. If you have a junkyard close you might be able to find one. Take plenty of PB Blaster if they wont let you have a saw, the nuts are a peal pain usually. I had the same problem when I swapped axles. I may have one left over from my swap but I don't remember which side it is, I can look if you are interested. Good luck TopHat |
