It is currently Wed May 06, 2026 7:41 am
 Post subject: Gas vs Alcohol
PostPosted: Sun Oct 21, 2007 7:08 am
Have both available to race with or even a blend.
Questions are:
1 whats the diference in preformance (ETs)
2 are there any considerations in the engine build?
This is Drag only Still considering a power adder car.
Thanks
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Oct 21, 2007 8:27 am
Alcohol motor will be able to use more compression than a pump gas motor. I have seen guys switch back and forth between race gas and methanol. Meth will make a ton more torque and will change less when the weather changes.
There is currently a lot of interest in E-85 because of the octane rating and cost. Main drawback I have seen so far is quality has been very spotty.
One thing to remember if you want to try and spray with alcohol. Your tune-up has to be spot on or you will hydraulic a cylinder and push the crank out.
Turbo works well with alcohol, but again, tune-up is crucial. :D
PostPosted: Sun Oct 21, 2007 12:07 pm
Thanks Dennis
So there isnt any special gaskets or what not between the two? I remember back in the mid 80s I couldnt run gasahol in my Toy truck (injector o rings or something) also bad proformance.
Would you sugest starting with a blend and work my way up?
You say Spray? like NO2?
I thought It was used to replace the gas. :oops:
Thanks
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sun Oct 21, 2007 2:04 pm
Nitrous (NOS) is used to augment the air, not replace gasoline. Nitrous is an oxidizer, and brings more oxygen to the combustion chamber. It is necessary to add additional fuel ( gasoline, alcohol, etc), when the nitrous is turned on.
PostPosted: Sun Oct 21, 2007 2:32 pm
Frank, I would either run gas or alcohol, never a mixture of both.
E-85 is the exception, but I'm guessing that's why there are fuel quality issues. Hard to get the mix right.
PostPosted: Sun Oct 21, 2007 5:49 pm
Thanks Guys
That makes good sense. Its nice to know that the motor will work with a power adder.
Frank
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
