| aluminum slant 6 https://slantsix.org/forum/viewtopic.php?t=25102 |
Page 1 of 2 |
| Author: | aluminum6 guy [ Wed Sep 26, 2007 9:38 pm ] |
| Post subject: | aluminum slant 6 |
I was reading an article " Aluminum Slant Six Engine Overview" and had a couple of questions about the numbering on the engine block. My block has many more numbers on it than in the article. I would like to know what they mean. Thanks |
| Author: | Sam Powell [ Wed Sep 26, 2007 9:44 pm ] |
I don't know anything about the numbers, but wonder if your engine runs. Is it in a car? You should feel good about having it at all, and I hope you get it going if it does not run now. Sam |
| Author: | Doc [ Thu Sep 27, 2007 10:34 am ] |
Die cast mold numbers and run dates. DD |
| Author: | aluminum6 guy [ Thu Sep 27, 2007 1:08 pm ] |
Quote: Die cast mold numbers and run dates. What exact info do these numbers represent?
DD |
| Author: | aluminum6 guy [ Thu Sep 27, 2007 1:13 pm ] |
Quote: I don't know anything about the numbers, but wonder if your engine runs. Is it in a car? You should feel good about having it at all, and I hope you get it going if it does not run now. It is a block that was never in a car. It was assembled, run in the Chrysler testing lab, torn down for inspection, and put away. It has been in indoor storage ever since. I am interested in decoding these numbers. Awsome car!!!
Sam |
| Author: | Wizard [ Thu Sep 27, 2007 5:06 pm ] |
Wow! A engine never in a car. That's a rare find. Cheers, Wizard |
| Author: | Sam Powell [ Thu Sep 27, 2007 6:35 pm ] |
Thanks man! I hope you find a nice car for your aluminum slant. Doctor Dodge is most likely the guy to help you figure out how to build it. Sam |
| Author: | aluminum6 guy [ Thu Sep 27, 2007 9:34 pm ] |
Quote: Wow!
Thanks. I looked long and hard to find it. I have had it in my garage for about 22 years. Now I am trying to find someone who can decode the numbers.
| Author: | aluminum6 guy [ Thu Sep 27, 2007 9:40 pm ] |
Quote: Thanks man! I hope you find a nice car for your aluminum slant. Doctor Dodge is most likely the guy to help you figure out how to build it. F ortunatly, I have been building racing engines for over 35 years. I am just curious on how to decode the numbers.
Sam |
| Author: | Joshie225 [ Thu Sep 27, 2007 10:36 pm ] |
Quote: F ortunatly, I have been building racing engines for over 35 years. I am just curious on how to decode the numbers.
Cool, how many were aluminum slants? Iron ones?
| Author: | Sam Powell [ Fri Sep 28, 2007 4:56 am ] |
In that case, Doctor Dodge is likely still the go to guy to get info on campatability of parts, gaskets, heads, cams etc. He is part of a racing community that has traveled this road more than a few times, and their advice is "priceless" as the Master CArd ad says. Sam |
| Author: | Doc [ Fri Sep 28, 2007 8:17 am ] |
Quote: I am interested in decoding these numbers
Is there a stamped number on the passenger side bell housing flange>Are the other number you discribed casted-in or stamped-in? DD |
| Author: | aluminum6 guy [ Fri Sep 28, 2007 1:47 pm ] |
| Author: | Doc [ Fri Sep 28, 2007 2:22 pm ] |
Are there any stamped numbers on the main ID Pad?
| Author: | aluminum6 guy [ Sat Sep 29, 2007 11:35 am ] |
Quote: Are there any stamped numbers on the main ID Pad? The only number on this block at that location is 7/16. Thanks Doc
| Page 1 of 2 | All times are UTC-07:00 |
