Info on Jahns pistons
https://slantsix.org/forum/viewtopic.php?t=2514
Page 1 of 1
Author:  Charlie Schmid [ Mon Aug 06, 2001 8:14 am ]
Post subject:  Info on Jahns pistons
I just got a set of Jahns high compression pistons for the slant. They are part number 1134 PRP .060.
Would any one have specs on these pistons? EI: weight, compression ratio, ring configuration, etc. Also a source for rings. Thanks.
Charlie
flturbo6@aol.com
Author:  Smith [ Mon Aug 06, 2001 8:34 am ]
Post subject:  Re: Info on Jahns pistons
Measure ring land widths(should be stock @ 5/64,5/64,3/16?) and check out <A HREF="http://www.hastingsmfg.com">www.hastingsmfg.com</A> for rings. They are very helpful and will respond via e-mail quickly. They also sell direct with a credit card.
sgw041454@aol.com
Author:  Doctor Dodge (Doug Dutra) [ Wed Aug 08, 2001 9:24 pm ]
: I just got a set of Jahns high compression
: pistons for the slant. They are part number
: 1134 PRP .060.
: Would any one have specs on these pistons? EI:
: configuration, etc. Also a source for rings.
Charlie,
The last set of Jahns pistions I used took factory .060 o/s rings. I do not have much info on the ones I used except that they were a cast "bucket style" piston with no steel expansion control strut. They were "full float" with a "pop-top" dome on them. I will say that I have put a bunch of 7,000 rpm passes on that engine with no problems. (yet)
