| Wheel studs.... https://slantsix.org/forum/viewtopic.php?t=25156 |
| Author: | shrt bus [ Mon Oct 01, 2007 5:53 am ] |
| Post subject: | Wheel studs.... |
Looking for wheel studs for a 63 Valiant. I am needing ones about 1/4" longer than stock? Anybody have part #'s by chance. I have been trying to find the "longer" versions..all I am so far finding are stock/OEM replacments.. Thanks Rick |
| Author: | GTS225 [ Mon Oct 01, 2007 2:15 pm ] |
Rick....Are you looking for the left-hand thread studs for the driver's side? The suppliers for those are limited, and you'll be out of luck for a longer version in southpaw threads. It is perfectly OK to change them all over to right-hand threads, and you should be able to find something at your local performance parts supplier. Roger |
| Author: | shrt bus [ Tue Oct 02, 2007 4:32 am ] |
Nopers.. just looking for right handed studs. The drivers side studs I pulled out were right handed as well, didnt realize they had left handed threads for the drivers side? I found some.. "hoping" they will be long enough .. as they are only 1/8" longer than OEM. Thanks! Rick |
| Author: | 64drtGt [ Tue Oct 09, 2007 3:59 am ] |
Go to napa I ordered a set because my stepdad didnt know they were left handers and broke all mine on one wheel. When I ordered them I thought that they were original length but these were about 1/4 -3/8 longer. |
