| alternator belt hitting lower radiator hose https://slantsix.org/forum/viewtopic.php?t=25175 |
| Author: | backwoodsbill [ Tue Oct 02, 2007 3:08 pm ] |
| Post subject: | alternator belt hitting lower radiator hose |
I put in a griffen radiator into my 63 valiant to make room put an electric fan in front, custom made my lower radiator hose but now my belt hits the lower hose. I can move my belt to the front grove on the crank pully and build out the water pump pully, But, How can I move my alternator out to match can I buy another pulley to take it out another 3/4 inch please help??? |
| Author: | Sam Powell [ Tue Oct 02, 2007 3:51 pm ] |
Some Mopar alterntors have two pulleys. maybe they all do, I don;t know. Is yours one or two? If only one, then maybe you can get the extra you need with the dual pulley unit. I would think the dual pulley one is for the AC set up. Sam |
| Author: | slantzilla [ Tue Oct 02, 2007 4:45 pm ] |
V-8 A/C alternators have the 2 groove pulley. |
| Author: | 70valiant [ Tue Oct 02, 2007 5:46 pm ] |
The "high output" alternators have 2 grooves all 59 amps worth. |
| Author: | Moparmodeler [ Wed Oct 03, 2007 6:09 am ] |
| Post subject: | I had the same problem |
I have a 72 Satellite, Yes I Know its a B-body. At one time some one replaced the original slant for a re manufactured slant. Shortly after buying the car I noticed that my belt was hitting the hose when revved up. I tried tightening the belt to no avail. I bought a NOS replacement hose that was shaped slightly different then the one that was on it. This and careful hose placement solved my problem |
| Author: | backwoodsbill [ Wed Oct 03, 2007 7:10 pm ] |
| Post subject: | Thanks for the tip |
I went to the junk yard bought a dual pulley brought ot home put it on lines up perfectly with the outside notch. THANKS FOR YOUR ADVICE |
