| 71 engine into a 66 https://slantsix.org/forum/viewtopic.php?t=25188 |
| Author: | FreeFish [ Wed Oct 03, 2007 1:24 pm ] |
| Post subject: | 71 engine into a 66 |
Is there anything other than the carb linkage that might cause me a headache? Will the 66 auto trans bolt up? Thanks, John |
| Author: | ValiantOne [ Wed Oct 03, 2007 1:52 pm ] |
If you intend to use the 66 trans you will need a bushing on the back of the crankshaft. I am doing the same thing right now and I am using the old manifold set and carb, so I can use all the same throttle linkages. There is a resource listed in Frank Adkins Chrysler Performance book for the crank bushing. If you need the info, let me know and I will look it up for you. Chris |
| Author: | ValiantOne [ Wed Oct 03, 2007 1:53 pm ] |
Oh yeah, the 66 flex plate won't work on the late model crank either. You'll have to get a post 68 flex plate. I am dealing with EXACTLY the same thing right now. C |
| Author: | Doc [ Wed Oct 03, 2007 2:15 pm ] |
The oil pan and pick-up tube fron the 66 engine needs to be used on the 71 motor. DD |
| Author: | FreeFish [ Wed Oct 03, 2007 7:33 pm ] |
Thanks everyone, I did a quick search and found a post about tflitepatty selling the bushings, so I sent an email. I hope the engine will come with the flex plate, so all else I have to do is find an oil pan gasket, and get the deal done with the engine. The fella I'm dealing with seems a little wishy-washy. Once again, I appreciate the advice. John |
| Author: | ValiantOne [ Wed Oct 03, 2007 7:51 pm ] |
Quote: The oil pan and pick-up tube fron the 66 engine needs to be used on the 71 motor.
Dang I need the oil pickup too?! Ugh. One of the guys on bigblockdart hipped me to the oil pan thing. (sorry I forgot that freefish) so I pulled the 66 pan last night. DD guess I'll be swappin' the tube tomorrow night:) Thanks Doc!! Chris E. |
| Author: | FreeFish [ Thu Oct 04, 2007 8:50 am ] |
One more thing, if I get the trans with it, will it match up to the driveshaft? drive train is coming from a 71 duster. My barracuda is a 66. Thanks again... |
| Author: | Doc [ Thu Oct 04, 2007 9:25 am ] |
Quote: One more thing, if I get the trans with it, will it match up to the driveshaft? drive train is coming from a 71 duster. My barracuda is a 66.
Yes, using the 71 trans with the engine is a good way to go for any 66 and up A-Body application.Thanks again... DD |
