It is currently Thu May 21, 2026 12:35 am
 Post subject: Please confirm ?!
PostPosted: Wed Aug 08, 2001 11:07 am
Went thru past postings concerning hyd. lifter engines/swaps. From what I read, I can use an '82 head on an early, solid lifter short block, as long as I use the solid lifter valve train and rocker shaft. I'll also have to use the late valve cover, as it was different than the early one.
Am I wrong here, or what?
Roger
GTS225@aol.com
 Post subject: Re: Please confirm ?!
PostPosted: Wed Aug 08, 2001 6:35 pm
: Went thru past postings concerning hyd. lifter
: engines/swaps. From what I read, I can use
: an '82 head on an early, solid lifter short
: block, as long as I use the solid lifter
: valve train and rocker shaft. I'll also have
: to use the late valve cover, as it was
: different than the early one.
: Am I wrong here, or what?
: Roger
That is what I have on my motor. You will also have to have the last "necked down" bolt from the hydraulic rocker shaft. I've had no problems so far. (Over 5000 miles and 100 passes)
aschumers@aol.com
