It is currently Wed May 20, 2026 11:41 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Valve seats/inserts?
PostPosted: Tue Aug 07, 2001 11:31 am
Got a late model head back from machine shop friday, with the bad news of a crack in the #5 exh. seat. Looks like only two options open at this time.....different core, or machine out for "insert", and hope the crack disappears. I have concerns about an "extra" piece of metal inside the combustion chamber, that might come loose, and perhaps hold that valve open for a face-to-face with the piston.
Anybody have any advice, pro's/con's, horror stories about the procedure? At this time, I'm leaning toward starting over with a different core. My prob is that slant stuff is getting rather scarce in my neck of the woods.
Roger
GTS225@aol.com
 Post subject: Re: Valve seats/inserts?
PostPosted: Tue Aug 07, 2001 10:23 pm
: Got a late model head back from machine shop
: friday, with the bad news of a crack in the
: #5 exh. seat. Looks like only two options
: open at this time.....different core, or
: machine out for "insert", and hope
: the crack disappears. I have concerns about
: an "extra" piece of metal inside
: the combustion chamber, that might come
: loose, and perhaps hold that valve open for
: a face-to-face with the piston.
: Anybody have any advice, pro's/con's, horror
: stories about the procedure? At this time,
: I'm leaning toward starting over with a
: different core. My prob is that slant stuff
: is getting rather scarce in my neck of the
: woods.
: Roger
I have used inserts in our engines for years. That is the LAST thing I would worried about. Any good machine shop can install them.
The last hot street engine I built had a set installed and they have been in their for over 60,000 miles.
damuel@kalama.com
PostPosted: Wed Aug 08, 2001 6:37 pm
: I have used inserts in our engines for years.
: That is the LAST thing I would worried
: about. Any good machine shop can install
: them.
: The last hot street engine I built had a set
: installed and they have been in their for
: over 60,000 miles.
I agree. As long as the shop knows what they are doing, inserts are trouble free.
aschumers@aol.com
