It is currently Wed Nov 18, 2026 5:58 am
 Post subject: Too much advance?
PostPosted: Sat Oct 06, 2007 8:23 pm
Instead of describing my question with needless rantings that cover a whole page, I'll post a simple open-ended question:
What is the effect on a motor if the cam is advanced too much?
I'll bet a slanter here has some "educated" knowledge about this... :D
PostPosted: Sat Oct 06, 2007 9:08 pm
Lots of power down low and runs out of wind around 4000 or so. :D
 Post subject: adv
PostPosted: Sun Oct 07, 2007 3:44 am
i second that ,i have run cams as much as 8degs each way and when advanced to much you have good grunt down low but the mph falls of :)
PostPosted: Sun Oct 07, 2007 8:00 am
Well, I asked because I run out of steam at about 70 mph. I advanced the cam 1 whole tooth. (About 15*) :shock:
Massive 4x4-like torque, but no road speed. Should I put it back a tooth?? Would I accelerate any faster? I'm thinking that with that much advance, Im running out of the powerband by about 2500. :shock:
Opinions? Suggestions?
PostPosted: Sun Oct 07, 2007 9:02 am
...Opinions? Suggestions?
Do you have a degree wheel. (you can print one off the internet)
Degree the cam, advance it 6 degrees from "split overlap" if you want low-end power.
Users browsing this forum: DuckDuckGo [Bot] and 7 guests
