| Too much advance? https://slantsix.org/forum/viewtopic.php?t=25240 |
| Author: | BigBlockBanjo [ Sat Oct 06, 2007 8:23 pm ] |
| Post subject: | Too much advance? |
Instead of describing my question with needless rantings that cover a whole page, I'll post a simple open-ended question: What is the effect on a motor if the cam is advanced too much? I'll bet a slanter here has some "educated" knowledge about this... |
| Author: | slantzilla [ Sat Oct 06, 2007 9:08 pm ] |
Lots of power down low and runs out of wind around 4000 or so. |
| Author: | terrylittlejohn [ Sun Oct 07, 2007 3:44 am ] |
| Post subject: | adv |
i second that ,i have run cams as much as 8degs each way and when advanced to much you have good grunt down low but the mph falls of |
| Author: | BigBlockBanjo [ Sun Oct 07, 2007 8:00 am ] |
Well, I asked because I run out of steam at about 70 mph. I advanced the cam 1 whole tooth. (About 15*) Massive 4x4-like torque, but no road speed. Should I put it back a tooth?? Would I accelerate any faster? I'm thinking that with that much advance, Im running out of the powerband by about 2500. Opinions? Suggestions? |
| Author: | Doctor Dodge [ Sun Oct 07, 2007 9:02 am ] |
Quote: ...Opinions? Suggestions?
Do you have a degree wheel. (you can print one off the internet)Degree the cam, advance it 6 degrees from "split overlap" if you want low-end power. DD |
