It is currently Wed May 13, 2026 9:39 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 3 posts ]
 Post subject: Info on Jahns pistons
PostPosted: Mon Aug 06, 2001 8:14 am
I just got a set of Jahns high compression pistons for the slant. They are part number 1134 PRP .060.
Would any one have specs on these pistons? EI: weight, compression ratio, ring configuration, etc. Also a source for rings. Thanks.
Charlie
flturbo6@aol.com
PostPosted: Mon Aug 06, 2001 8:34 am
Measure ring land widths(should be stock @ 5/64,5/64,3/16?) and check out <A HREF="http://www.hastingsmfg.com">www.hastingsmfg.com</A> for rings. They are very helpful and will respond via e-mail quickly. They also sell direct with a credit card.
sgw041454@aol.com
PostPosted: Wed Aug 08, 2001 9:24 pm
: I just got a set of Jahns high compression
: pistons for the slant. They are part number
: 1134 PRP .060.
: Would any one have specs on these pistons? EI:
: configuration, etc. Also a source for rings.
Charlie,
The last set of Jahns pistions I used took factory .060 o/s rings. I do not have much info on the ones I used except that they were a cast "bucket style" piston with no steel expansion control strut. They were "full float" with a "pop-top" dome on them. I will say that I have put a bunch of 7,000 rpm passes on that engine with no problems. (yet)
